aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade. Anyone seen this ? Rega...
nitropower
May 04, 2022Tutor
UPDATE
The connection from Router to Sat is now direct no switch and the VLAN/BRIDGE setting for the two router lan ports used in the network.
set for Default1 the Wireback haul now shows connection and firmware at correct levels.
Bryan
BruceGuo
May 04, 2022NETGEAR Expert
Do you think the switch caused firmware upgrade not working?
- techcomm2022May 05, 2022Aspirant
Not sure if so it a Netgear Switch you would expect them to test it with their own gear.,
Update Two after the test I also tried wireless back haul as I expected the satellite to not connect but it connected fine via wireless.
We will run the class rooms via wireless this week to make sure no issues,
Bryan
