aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade. Anyone seen this ? Rega...
May 05, 2022Guru - Experienced User
Ok. That's a managed switch. Seen some manages switches cause problems for some users. One user mentioned years ago about disabling all IGMP protocols on these switches was a solution. Might give this a try. Not sure if Orbi pro would be affected in same way as Orbi Home though. Also seen some switches with Green Ethernet features cause problems as well, tough I was given feedback about Orbi Pro shouldn't be bothered by this. Otherwise give a non managed switch a try between the SXR and SXS.
nitropower
May 05, 2022Tutor
Yes they cause issues we had to disable the port disabling features for the ports ORBI are connected it appears the switch see them as loops.
It took me like 3 hours to find a resources that understood the switch after it was installed and started to disable port after port that router was connected to.
Switch was supplied by VOIP contractor.
We had just old JGS524E before no issues!
Technology got to love it.
Bryan
- FURRYe38May 05, 2022Guru - Experienced User
Ya, give the IGMP protocol a try on that switch.
These switches and Orbi are kind of corner case issues. Seen this happening since Orbi 50 series. The communications between Orbi routers and the satellites seems specific and anything getting the way seems to cause problems. 🙄
Why we recommend non managed switches as first option to try.
Always something with tech. 😜
- nitropowerMay 05, 2022Tutor
Ok all green Ethernet disabled
L2 loops are all log only for all ports
DOS auto disabled as the switch behind FW
lets see how this works
Did you find any IGMP options on this switch?
