Dukennl's avatar
Dukennl
SXR50 - Insight app and site not in sync with Orbilogin
Dear,
The orbilogin and insight app / website is not in sync. Items are not updates and i can't update anything from the site.
There errors:
The following operation did not execute completely:
Details:
Device Name: XXXX
Network Name: XXXX
Serial Number: XXXX
Model: SXR50
Failure Reason: Unable to update guest SSID for device Router
Sincerely,
The NETGEAR Insight Team
and
in the logs:
[Insight] configd init completed., Sunday, November 20, 2022 12:21:35
[Insight] Failed to post monitoring data. r = -1., Sunday, November 20, 2022 12:21:35
[Insight] Failed to get monitoring data from configd., Sunday, November 20, 2022 12:21:35
[Insight] insight-configd was started., Sunday, November 20, 2022 12:21:35
[Insight] Failed to post monitoring data. r = -1., Sunday, November 20, 2022 12:21:32
[Insight] Failed to get monitoring data from configd., Sunday, November 20, 2022 12:21:32
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Dukennl,
    Welcome to the community! 🙂
    Found out from the NETGEAR Support Team that you have already contacted them.  You may want to share the progress of your support ticket number here.
    DaneA
    NETGEAR Community Team
    • Dukennl's avatar
      Dukennl
      Yes i did, support was nice but the product is a mess.
      You mis al lot of options on the https://insight.netgear.com/ or the app to maintain the router. So when you use https://orbilogin.com/ to manage your device to use the options like a schedule on the wifi or renaming devices the sync will break between the orbi and insight.
      And... that is normal.. is a known issue from netgear. They don't know if the issue can be solved. 😞
      I need to maintain the config on https://orbilogin.com/... the interface from 1990 that cant be used on a phone.
      Netgear don't call this a pro device. The WiFi is great but maintaining it is a hell. 😞
      But hey! I get a 5 years subscription on insight that can't be used! Great....
      • Dukennl's avatar
        Dukennl
        But... i can finally forward the service from Quake 2 & 3 on my Pro Orbi! Woopie! 🤣
ProSupport for Business
