asefd
Feb 05, 2022Tutor
SXR80 - Bridge Mode
Hello, Is it possible to put in Bridge Mode the Orbi Wifi 6 Pro SXR80 just like an ordinary WiFi router? Thanks
Feb 06, 2022Guru - Experienced User
What exactly by bridge mode do you mean? different manufacturers call it different things.
Are you looking for access point mode?
- asefdFeb 07, 2022Tutor
Hi,
Yes AP mode. So I could connect multiple routers and expand the coverage.
Thanks
- plemansFeb 07, 2022Guru - Experienced User
yes you can use access point mode.
But you also put multiple "routers". The SXK system uses 1 router with multiple satellites.
Thank you for your reply.
Our need is to put multiple routers with satellites on different floors and have the same SSID on each floor.
