asefd
Feb 05, 2022Tutor
SXR80 - Bridge Mode
Hello, Is it possible to put in Bridge Mode the Orbi Wifi 6 Pro SXR80 just like an ordinary WiFi router? Thanks
asefd
Feb 07, 2022Tutor
Hi,
Yes AP mode. So I could connect multiple routers and expand the coverage.
Thanks
Feb 07, 2022Guru - Experienced User
yes you can use access point mode.
But you also put multiple "routers". The SXK system uses 1 router with multiple satellites.
- asefdFeb 07, 2022Tutor
Thank you for your reply.
Our need is to put multiple routers with satellites on different floors and have the same SSID on each floor.
- plemansFeb 07, 2022Guru - Experienced User
How many are you thinking?
have you looked into moving to the fully business grade with insight?
- asefdFeb 07, 2022Tutor3 of the floors : 1 router + 5 satellites (+/- 19000 sq ft)
1 floor: 1 router + 3 satellites (+/- 12000 sq ft) .
These are underground parking floors.
I wasn't aware of this solution. Unfortunately I never received an answer frop Netgear support to help me choose the necessary equipment....
Any link or particular model I could search for?
Thanks in advance
