Chris47111
May 16, 2021Aspirant
SXR80 and IOT
dear community, I recently got myself a SXR80 Pro and a SXS80 Pro satellite. My goal was to get my IOT- devices (apple TV, hue) out of my regular lan. So I connected these devices via dlan (le...
- May 17, 2021
There seems to be some confusion (perfectly valid): The LAN1...LAN5 in the UI describe dedicated networks/VLANs, not the LAN port per se (the user manual can be confusing). There is also a predefined VLAN Profile config for the IoT VLAN. To change the VLAN profile for the LANx, you must change the VLAN profile used for the associated LAN Ethernet port and wireless network.
schumaku
May 17, 2021Guru - Experienced User
- Chris47111May 17, 2021Aspirant
Thanks, it works now!!!
- AquaLabAquariaMay 22, 2021Guide
When you say this, are you referring to the VLAN bridge settings page?
- Chris47111May 22, 2021Aspirant
Exactly.
