Cafetom
Oct 25, 2022Star
SXR80 and SXS80 Firmware stability question to 4.2.3.102
Hello All,
I've updated my firmware via the "I believe" button through the web interface of the base unit a few days ago.
Since the update, Insight shows the device going offline and online at least 6 times a day, for 3-10 minutes at a time. I have confirmed that it is indeed offline and do not have any ISP issues.
I did perform the post firmware update procedures outlined in the readme.
Anything else I should do or is there another issue?
Tom
I have rebooted the router, but do not have physical access to the satellite. I do not see any way to reboot the satellite through the web interface, http;//ipaddress/reboot.htm doesn't work.
- JeraldMNETGEAR Employee Retired
Hi Cafetom,
Given that you don't have physical access to the satellite, is it also the same case for the router? Were you able to perform a reboot on the router via web interface, NETGEAR Insight, or physically?
Lastly, please try removing the device from NETGEAR Insight then add it back to see if that'll resolve the issue.
JeraldM
NETGEAR Community Team
