brjacobso
Sep 08, 2022Tutor
SXR80 and SXS80 losing connection constantly
Business WiFi Mesh System latest firmware V4.2.2.130 #SXR80 and##SXS80 pair (1 each Yesterday, I started losing connection every 10 mins. The only remedy is either to power cycle the Router or t...
brjacobso
Sep 08, 2022Tutor
It's in router mode, but connected to a separate AP from my ISP by cat 7 or 8 cable. So I get fiber from AT&T, they have the fiber go into their AP box. I disabled its integrated wifi because I want to use the mesh of these Orbi devices. Then the orbi has one satellite to help bring the signal to the rest of the house. I have a couple things wired to the orbi router, but the rest of everything is by wireless to either R or S.
Correct, I'll be just working on my work laptop, trying to go to a webpage or send messages in various messaging apps like microsoft teams. Every app that has a way of letting me know they're disconnected starts letting me know, web pages in browsers start going to 'can't access that right now' type messages.
And then if I go to my phone, I'll get the message "do you want to switch to cellular data or continue trying the wifi?".
Sep 08, 2022Guru - Experienced User
swtiching off the wireless on the att gateway doesn't disable its router functions. It still leaves you in a double nat.
If you have their gateway in router mode, try the netgear in access point mode. that'd fix your double nat.
- brjacobsoSep 08, 2022Tutor
Well, I kind of want that. I'm serving up a number of VLANs and using other features that won't be possible if I do AP mode, at least according to some quick searches. AP mode seems to give out IPs on the original LAN that the main AP I have from my ISP is serving. I'll keep researching that as an option. But I don't think that solves the original issue. I've had this setup for about a year without issues. It's been the most stable and fastest wireless I've ever had...until a few days ago.
- plemansSep 09, 2022Guru - Experienced User
So try going into the att gateway and putting the netgears IP address into its DMZ
- brjacobsoSep 09, 2022Tutor
Ok, thanks. I did end up getting into my ISP's AP to look at settings. I did find pass through mode, and I specified the mac of the orbi router. That's working pretty well right now, so I think that will fix it. I'll see in a few days, if I don't get disconnected anymore I'll be happy. The other funny thing is that the sticker on the orbi has the wrong mac address, it was off by 1 on the last hex digit. I'm glad the AP's tool page detected mac's for me. If I had to type it in from the sticker, it would not have worked. I wonder if the orbi router has an external mac and an internal mac somehow. Anyway, I'll update if anything goes wrong and in a few days find out if there's a way to mark this all solved.
