Obmit
Dec 03, 2021Aspirant
SXR80 Port Forwarding
I am having issues with my Somfy blinds. I have no issues with any other IOT devices. All connect and talk to eachother and my phone both in and off my home network, for example my garage I can open ...
Obmit
Dec 06, 2021Aspirant
Thanks for all of that info.
The somfy is on Wifi 3, with all of my other IOT devices. My Kasa, Hue and Google devices can all get out to the world and I can control things from my phone without being on the wifi.
Perhpas one mysetery we can solve while I find out more about the Smfy gear is why I can not detect the open ports using ay online tools. According to the settings, I have them open. See picture. I have tried with UPnP on and off.
WHen you say PRIMARY NETWORK, what do you mean? Wifi 1?
Thanks
schumaku
Dec 07, 2021Guru - Experienced User
All these are typical IoT which establish only an outgoing connection to the Internet where certain reverse or tunnel methods are used from where the App resp the cloud infrastructure the App does talk to can reach the IoT devices on your network.
Agree, lot of mystery, paired with some odd support feedback by these vendors. Probably French to English translation issues (kidding).
The ports shown are forwarded manually to the Somfy controller one might guess. but as we both suspect, there is no incoming connection required - this would break users located behind double NAT, where ISP deploy carrier grade NAT (again leading to double NAT), and last but not least exposing these "thin" controllers to the wild Internet. thus very unlikely, as you already figured out, too.
Some smart design might allow certain connection-less access direct from the App on the local (W)LAN to avoid the loop over the cloud - wound be hard if you can't open the shutters in the morning or in case of a strom while the Internet is down.
Yes. As far as I understand the UPnP PMA works only on that WiFi 1 - can't think this should be required. Convinced BruceGuo can support my confused old brain please.
