duanemitchell
Mar 11, 2022Star
SXR80 Series Firmware Version v4.0.0.118
Hello, I received an email on 3/9/2022 alerting me to a firmware update for my SXR80 router and SXS80 satellite. I went to this page and downloaded the update package. https://www.netgear.com/su...
- Mar 11, 2022
Using the Insight app worked. It updated both the router and the satelite. Last time I tried this method it failed. I think it was a timeout issue relating to the download? Not sure.
If I log back into the router it does show the new firmware as being installed.
I prefer the web interface to the router over the app. Not sure why that didn't work?
Thanks for pitching in.
Duane Mitchell
Mar 11, 2022Guru - Experienced User
If you click on that box by the satellite (under model name: sxs80), then click update, it'll take you to where you can upload the firmware to for the satellite.
If that doesn't work, you can try the satellites ip address (found in the attached devices page)
- duanemitchellMar 11, 2022Star
I tried that. It opens another browser window for the IP address of the satelite and requires that I login. I don't know what the login is for the satelite? It was all configured through the base router. It's not the same login as the router.
Duane Mitchell
- plemansMar 11, 2022Guru - Experienced User
It should be the same as the router.
You can always try the default login
default login: admin
default password: password
The default login credentials don't work. Neither does the router credentials.
I rebooted the router and now I can't login with any credentials.
I switched to the Insight app on my iPhone and that detects a firmware update so I'm trying that. That process turned into a mess last time I tried it. Let's see what happens. I'll report back.
Duane Mitchell
