duanemitchell
Mar 11, 2022Star
SXR80 Series Firmware Version v4.0.0.118
Hello, I received an email on 3/9/2022 alerting me to a firmware update for my SXR80 router and SXS80 satellite. I went to this page and downloaded the update package. https://www.netgear.com/su...
- Mar 11, 2022
Using the Insight app worked. It updated both the router and the satelite. Last time I tried this method it failed. I think it was a timeout issue relating to the download? Not sure.
If I log back into the router it does show the new firmware as being installed.
I prefer the web interface to the router over the app. Not sure why that didn't work?
Thanks for pitching in.
Duane Mitchell
duanemitchell
Mar 11, 2022Star
I tried that. It opens another browser window for the IP address of the satelite and requires that I login. I don't know what the login is for the satelite? It was all configured through the base router. It's not the same login as the router.
Duane Mitchell
Mar 11, 2022Guru - Experienced User
It should be the same as the router.
You can always try the default login
default login: admin
default password: password
