hawkinsR's avatar
hawkinsR
SXR80 w/ Wavlink WL-WN573HX1
Does anyone know if the Wavlink WL-WN573HX1will work inmesh extendermodewith the SXR80 router?
  • schumaku's avatar
    schumaku
    This is what the https://www.wavlink.com/en_us/product/WL-WN573HX1.html FAQ says:
    Is the Wavlink Everything Mesh WiFi system compatible with other mesh systems?
    The Wavlink Everything Mesh WiFi system is a proprietary mesh system and is not compatible with other brands of mesh networking systems. If you have purchased several Wavlink Everything Mesh devices, you can interconnect them to create an overall mesh network covering a wider area.
    Said that, the same applies to the Netgear Orbi Pro WiFi 6 systems.
    • hawkinsR's avatar
      hawkinsR
      In that case, I suppose I am looking for an inexpensive repeater or Ap, I do not care about the mesh part of it, I just need wifi so smart landscaping can be accessed. I'd hate to trash the netgear, look elsewhere & system and start over, but will if I must
      • schumaku's avatar
        schumaku
        Difficult to help if an undefined smart garden project is the key of the universe.
        Your SXx80 system does not cover the garden by Wi-Fi? Any SXS80 satellites deployed? You can always add SXS80, SXS50 or SXS30 Orbi Pro WiFi 6 satellites, being by using a wireless or a wired backhaul.
ProSupport for Business
