jbsate
May 23, 2024Aspirant
SXS80 w wired backhaul runs ok for a while, then loses connection to router
After upgrading SXS80 to 4.3.3.200 firmware for SXR80 router and satellite, all comes up fine. But after a while (hours, days) the connection drops to the satellite. It is hard-wire connected to the ...
May 30, 2024Guru - Experienced User
Can you let us know how the SXS are ethernet connected to the SXR? Directly behind the SXR or is there a LAN switch or LAN patch panel in the middle?
What CAT# LAN cable are you using? CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between SXR 📡 and SXS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
What channel configurations are currently set on the router?
