Nandeesh
Jan 19, 2022Follower
This connection is secured
When i try to access the router from outside the office using publice IP,(Ex https://pulic ip:8443) getting a message "Your connection isn't private". Kindly suggest how to come out this issue and a...
schumaku
Jan 19, 2022Guru - Experienced User
As along as you use an IP address, even with a trusted and signed certificate, the message would not change much.
Unless I'm wrong, there is neither a feature for importing a certificate (signed by a CA), import and keep the certificate current automatically (Let's Encrypt), nor to generate at least a self-signed certificate.
BruceGuo - these would be about the minimum requirements for a "Pro" device.
