KEWenz
Feb 05, 2022Follower
Top light does not turn on and router doesn't work - Is it bricked?
My Orbi Pro Tri-Band mesh system was working fine for 1.5 years, and a few days ago it stopped working altogether. The top light on my SRR60 router does not turn on at all (but the green power light...
Feb 06, 2022Guru - Experienced User
Tftp is very sensitive to timings. It can take a few times to get it to work.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
