Jet441's avatar
Jet441
Tracking web pages accessed by a device
Hello,
I'm new with Netgear interfaces and settings.
I just installed Orbi Pro SRK60.
How can I track which web sites were visited and when either by device MAC adress or IP adress?
I look in the journal but I can't find anything.
Thanks for your help
Tx
  • Hi Jet441,
    Welcome to the community! :)
    On the Orbi Pro, you may want to view and manage logs.  Kindly read page 83 of the Orbi Pro user manual here on how to View and Manage Logs of Router Activity
    Also, (just sharing) I found online about Veriato and ActivTrak.  You may want to search in-depth about them.
    DaneA
    NETGEAR Community Team
  • you need 3rd party software to do that; its not part of the included software on the orbi
    • Jet441's avatar
      Jet441
      Thanks for your quick answer. Any suggestion for the 3rd party software to use?
      Thanks
      • DaneA's avatar
        DaneA
        NETGEAR Employee Retired
        Hi Jet441,
        DaneA
ProSupport for Business
