pellison
Jul 19, 2023Initiate
Trying to sync SXS80 with another router than the one iit was delivered with
HI. I need 5 AP units for full coverage across our facility, so i purchased 2 orbi 6000 3-packs, looking to use only the satelites from the second pack together with the first pack. Got the first pac...
- Jul 20, 2023Thx. This is what I have done all along. Found a thread suggesting that I did the sync had wired. This worked!
Jul 19, 2023Guru - Experienced User
try hardwiring the satellite into the router and syncing it. (give it a bit).
Make sure they're on the same firmware.
when you disconnect it, it should stay sync'd
- BasuKhodanapurJul 20, 2023Apprentice
Hi pellison ,
Please follow below mentioned steps, it will help you to add satellites wihtout any issue
Press the reset button in the second 3-pack's satellite, after satellite reboot and booting up around 3 mins, running the sync in the admin browser and prepss the wps button in satellite, it only allows to connect one satellite each time, please try it in each second 3-pack's satellite.
Because we don't know what configurations are there in second 3-pack's satellites, so reset is the better option to make sure everything works well.
Thanks,
Basavaraj
- pellisonJul 20, 2023InitiateThx. This is what I have done all along. Found a thread suggesting that I did the sync had wired. This worked!
