aalrashid
Nov 02, 2024Aspirant
Updated srr60 to latest firmware, everything stopped working
I have srr60 with 5 satellites. It was running 2.6.2.202, so I updated all through up address to 2.7.3.100. When it finished, everything stopped working and it keeps asking to enter my isp username an...
Nov 02, 2024Guru - Experienced User
Was the SRS updated before the SRR was?
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Make sure the information is correct from the ISP. Contact the ISP to check this.
SRR are not user configurable. They are auto configured and connected by the SRR.
- aalrashidNov 02, 2024AspirantI tried all of that and isp confirmed details, still doesn’t work. This is what’s showing
- FURRYe38Nov 03, 2024Guru - Experienced User
What is the brand and model of the ISP modem or ONT the SRR is connected too?
You may need to do a full on factory reset on the SRS and SRR and set up from scratch using a wired PC and web browser.
