JBQuinnforRCRC's avatar
Jan 22, 2025
Using DHCP Rather Than Static Adress to Hook To Internet Using Orbi SXR30
We have an ORBIPro SXR30.  Currently it hooks to the internet through a Fiber modem.  It uses a static address for the IP Gateway on the router WAN settings.
We are changing services.  The new service is COAX from Spectrum.
Do I really need a static address to hook to the modem or can I use DHCP and allow the Spectrum ISP to assign the address.  Is that what the Assign IP Address Automatically does in the WAN IP (not LAN) section of the configuration.
  • FURRYe38's avatar
    Something to ask the ISP about. Most common ISPs use DHCP. There are some that may need specific configurations. The ISP will know this.
  • plemans's avatar
    You should be fine.
    Unless you're using the static public IP address (different from private) for outside services/servers
ProSupport for Business
