BooJangles
Sep 21, 2019Apprentice
V2.4.0.114 Update wired backhaul no longer working
After updating to firmware V2.4.0.114 wired backhaul stopped working. I have srr60 router and 6 srs60 satellites. All worked fine on V2.3.5.108. Before I attempt to rollback, did anybody else ha...
- Sep 22, 2019It ended up being a bad switch GS108.
Thanks
davidcheok
Sep 22, 2019Apprentice
Wired? It works on mine. Tried rebooting it, checking the dhcp is enabled and pinging the router and satellites to see if they have an assigned IP?
BooJangles
Thanks
Thanks
- davidcheokSep 22, 2019Apprentice
Hehe. Yeah it happened to me before too. Hence the ping and trace route tools are my best buddies. Hahaha.
Should update the thread with solution accepted. Else others might think its on-going.
