jcharnet
Jun 25, 2021Guide
Very low speed on 2.4ghz
My router is SXR80, but it’s not on the list. I have 1gbps fiber, and my wifi runs around 700/800 mbps when on 5G. I have one satellite with Ethernet backhaul connected. From the satellite I also ...
jcharnet
Jul 05, 2021Guide
I am using inSSIder to analyze my wifi. I did see one other wifi using the same channel, 6, so I changed mine to 1, which didn’t have any other wifi on that channel. It got soooo worse. Couldn’t even connect to the internet. Had to go back to Auto, and still facing very low speed at 2.4ghz.
schumaku
Jul 05, 2021Guru - Experienced User
Things still possible are either other WiFi devices you won't see on air (no name or network announced), or even worse other 2.4 GHz applications heavily using the very narrow public band with comparable aggressive technologies e.g. for applications like HDMI or other bandwidth hungry, not using WiFi standard technologies at all.
- jcharnetJul 05, 2021GuideThe spot I’m seeing this very low speed is in my backyard, with no other devices near by. There’s a TV, but I’m testing with the TV completely off, and unplugged from the outlet just to make sure there’s no interference.
Any other ideas I can try to troubleshoot?- jcharnetJul 13, 2021Guide
No other recommendations?
Would it help to have an access point closer? Even though the signal is great, 3 out of 3 bars full. Not sure if the AP will use the same channel or a different one.
Thoughts?
Thank you,
Joao
