jcharnet
Jun 25, 2021Guide
Very low speed on 2.4ghz
My router is SXR80, but it’s not on the list. I have 1gbps fiber, and my wifi runs around 700/800 mbps when on 5G. I have one satellite with Ethernet backhaul connected. From the satellite I also ...
jcharnet
Jul 05, 2021Guide
The spot I’m seeing this very low speed is in my backyard, with no other devices near by. There’s a TV, but I’m testing with the TV completely off, and unplugged from the outlet just to make sure there’s no interference.
Any other ideas I can try to troubleshoot?
jcharnet
Jul 13, 2021Guide
No other recommendations?
Would it help to have an access point closer? Even though the signal is great, 3 out of 3 bars full. Not sure if the AP will use the same channel or a different one.
Thoughts?
Thank you,
Joao
