jcharnet
Jun 25, 2021Guide
Very low speed on 2.4ghz
My router is SXR80, but it’s not on the list. I have 1gbps fiber, and my wifi runs around 700/800 mbps when on 5G. I have one satellite with Ethernet backhaul connected. From the satellite I also ...
DaneA
Jun 28, 2021NETGEAR Employee Retired
Are there other 2.4GHz wireless network/s within the area where the SRX80 is deployed?
Have you tried changing the channel on the 2.4GHz wireless network of your SRX80? If not yet, kindly try to change it and observe.
What is the current firmware version of your SXR80? If ever its not yet the latest version, I suggest you to update it then check if the same problem will occur. The latest SXR80/SXS80 Firmware is v3.2.6.100 and you can download it here.
DaneA
NETGEAR Community Team
lenadavids
Aug 08, 2021Aspirant
DaneA
What if there is problem with microwave thing means this can be interfare the signals then what should we do?
