Bighardyfamily
Jul 01, 2022Initiate
Vigor 167 and Orbi SK30 Help
I have got an Orbi SK30 that i want to use with a new Vigor 167, and i was wondering if someone could point me in the right direction as what mode the Vigor needs to be in, guessing modem ? (as the o...
Jul 01, 2022Guru - Experienced User
it should just be with the vigor in modem mode and then filling in your isp stuff on the orbi.
but if it doesn't work, you could leave the vigor in router mode (disable its wifi) and put the orbi in access point mode.
- BighardyfamilyJul 01, 2022Initiate
Really want to use the Orbi as router as i want to use the VPN, will try it tonight 🙂
