NemoNeil
Apr 28, 2022Guide
VLAN Configuration when you have a Switch in your Network?
Hi
I have the SXK80 Router and Ethernet Port 1 is connected to Modem(Internet) which has default VLAN 1 assigned and Ethernet Port 2 is connected to a 4 port switch and configured to VLAN 2. Port 3\4 have computers connected to it.
I have another VLAN 3 setup as IOT
The switch has Printer and Computer and Security Camera connected to it.
Now problem is everything is going through VLAN 2 as the switch is connected to port 2, but how do i configure the Orbi to say that SecurityCam should be routed to VLAN 3 (IOT)
I want to utilise the switch as i dont want to remove the camera from the switch and plug it directly to the Orbis spare port.
Can orbi Pro be configured in such way? do i need additional equipment? or am i doing somthing wrong?
Any help appreciated. Thanks
- JeraldMNETGEAR Employee Retired
- NemoNeilGuide
Thanks Jerald
Its a shame you dont get this out the box! I paid £1000+ for a business wifi router router and doesnt allow you to creat rules to allow you to talk to other vlans (inter-VLAN routing)
Bit disappointed and will consider returning this. I see others have also suggested inter-VLAN routing in the suggestions and nothings been implmented to date?
anyway, appreciate your response
Thanks
- BruceGuoNETGEAR Expert
Assume Router is in "Router mode".
WAN is connected with a modem
LAN1 is with VLAN2.
The switch is under VLAN 2 so camera, printer, computer are under VLAN 2 as well.
I guess you consider camera is an IOT device. So you want to assign VLAN3 IP to the camera. Then, PC under VLAN 2 can communicate with camera under VLAN3?
If my understanding is correct, you need to configure:
downlink port of SXR80 in trunk mode and with default VID.
Configure uplink port of the switch in trunk mode.
Configure VLAN3 in the port that camera connects to
Configure VLAN2 in the port that Printer and PC connect to
It make sure the uplink port and downlink port can forward tagged packet without modification. Then, PC and camera can communicate when they are in different subnets.
Router can route the packets.
Bruce
