Olivier_C
Dec 09, 2020Aspirant
VLAN Issue on Orbi Pro Wifi 6 Sattelite
Correct model: not available on the Model list: SXS80 – Orbi Pro AX6000 Wifi 6 Hi, I've got a VLAN issue on my Orbi Pro AX6000 Wifi 6, regarding configuration replication between router and satt...
Olivier_C
Thanks schumaku for this quick answer.
You are right, I frogot to mention that the stellite is running with the wireless backhaul, not wired...
Snif... a bug on the V3.1.0.104 firware release.
I will open a case to the support to see if there is any reference to this issue.
Orbi_ER
Dec 09, 2020Tutor
Olivier_C - You're not alone in that issue. I'm working through the same challenge with my system and currently have support looking into it. I stopped using the satellite because of it, as it was putting any device connected to it on the default LAN (which I'm not even using in my network setup). I tried it with both wired and wireless backhaul with the same results.
- RaghuHRDec 10, 2020NETGEAR Expert
We have some known issue around VLAN & Satellite combination. We have fixed this and it will be part of next releases. We can share beta FW if you would like to try. Please PM me.
Thanks,
Raghu
- ctjacobsonDec 13, 2020Aspirant
I am also having the same issues. I just updated to the new released firmware 3.1.1.102 and still having the issue. What code is the fix going to be on? How can I get the Beta FW to see if its fixed?
Thanks,
ctjacobson
- JasperCDec 14, 2020Tutor
Orbi Pro WiFi 6 (SXK80). Hi. I opened a ticket for this issue on 11/17/20. Support worked with me and on 12/10/20, I was notified that engineering confirmed it is a bug and a firmware update will be released in mid-January. I'm going to try to keep my support ticket open until I have verified that the January updated does correct the issue.
- DaneAJan 13, 2021NETGEAR Employee Retired
Olivier_C / JasperC / ctjacobson / Orbi_ER,
Orbi Pro WiFi 6 Firmware v3.2.0.108 has been recently released. It fixes the issue where clients connected to a satellite gets the wrong IP address from a VLAN on a WiFi network. As reference, kindly read the release notes and you can also download it here.
DaneA
NETGEAR Community Team
