Olivier_C
Dec 09, 2020Aspirant
VLAN Issue on Orbi Pro Wifi 6 Sattelite
Correct model: not available on the Model list: SXS80 – Orbi Pro AX6000 Wifi 6 Hi, I've got a VLAN issue on my Orbi Pro AX6000 Wifi 6, regarding configuration replication between router and satt...
Orbi_ER
Dec 09, 2020Tutor
Olivier_C - You're not alone in that issue. I'm working through the same challenge with my system and currently have support looking into it. I stopped using the satellite because of it, as it was putting any device connected to it on the default LAN (which I'm not even using in my network setup). I tried it with both wired and wireless backhaul with the same results.
DaneA
Jan 13, 2021NETGEAR Employee Retired
Olivier_C / JasperC / ctjacobson / Orbi_ER,
Orbi Pro WiFi 6 Firmware v3.2.0.108 has been recently released. It fixes the issue where clients connected to a satellite gets the wrong IP address from a VLAN on a WiFi network. As reference, kindly read the release notes and you can also download it here.
DaneA
NETGEAR Community Team
