VPN_ISSUES
Nov 25, 2020Follower
VPN issues with Global protect and SSR60
Our Orbi Pro SSR60 mesh system suddenly developed issues with my employer's VPN in September and our ISP and my company IT dept have not been able to resolve it. They both seem to agree that it has s...
JohnC_V
Dec 03, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having some problems with your Orbi Pro system. May I know if this is working before? If it does, did it happen before you upgrade the firmware to 2.5.5.100? If not, please try to upgrade the firmware to 2.5.5.100 and reset it to factory default afterward.
John
NETGEAR Community Team
Searly__
Jan 11, 2021Aspirant
Hi,
I have the DM200 Modem, and since installing my wife and I both havent been able to connect to our seperate companies global prtoect VPN.
Excatly the same issue as mentioned in the original question?
Is this something I can fix?
There was no issues until i chnaged to the DM200.
Thanks
Daniel
