Retired_Member's avatar
Retired_Member
Sep 23, 2021
What FW version?
Hello,
I am just confused....but what FW should I be running?  SRR60
Currently at 2.7.0.110......should I be at 2.6.2.202 Hot Fix?
thanks
  • You're on the correct one.
    Sometimes that auto-update server gets the update before the manual update server.
1 Reply
  • plemans's avatar
ProSupport for Business
