SteveinPortland's avatar
Jul 12, 2021
Wired backhaul drops internet connection - Orbi Pro 6
Want to set up a wired backhaul, but when I connect the satillite to the base unit I lose internet connectivity on the satillite.  I'm using CenturyLink and had to set up a VLAN (on 201).  Any thoughts?
Thanks
Steve
  • schumaku's avatar
    schumaku
    RaghuHR several similar posts - either LAN ports not working, or wired backhaul not working, ....
  • I had to move the both Ethernet ports connected to my patch panel switch to be set to VLAN Profile to 1(Default) & Mode to Trunk under Advanced --> VLAN/Bridge Settings
    • SteveinPortland's avatar
      SteveinPortland
      Alas, no luck.  When I plug the switch onto port 1 on the base the computers connected to the switch can see the network, but can't get access to the internet (including the satillite).  Some additional information:
      - my ISP is Centurylink.  I had to set up a new VLAN ("internet") on port 201 and set the WAN port on the base to use this VLAN in order to get internet
      - the other ports on the base/satillite can connect to any VLAN execept "internet" (it's grayed out)
      - one thing I haven't tried - initially the Centurylink tech and I tried to set the "bridge/VLAN group" to 201, but it didn't work, hence the creation of the new VLAN.  It's still set to 201 - once I get some time where the family isn't complaining about lack of internet I will reset it to "1" and see what happens (the other ports are set to "default", which is set to "1", so I'm not holding out hope)
      - "mode" is set to "truck" for all ports.  Will do some research to see if setting it to "access" will make a difference
      Thanks for the help.
      Steve
ProSupport for Business
