Orbipro1
Jul 27, 2021Aspirant
Wireless user separation
wireless 1 says this is the most secure and use for admin. How do i separate users on 2 or 3 and make them as secure as wireless 1 ?
Orbi Pro AX model? Associate the Wireless 2 and 3 profiles with dedicated VLANs for example.
- Orbipro1Aspirant
how is wifi 1 the safest and how do I make the other networks as safe? I read that vlan has leak vulnerabilities. Is the basic router setup a one lan a vlan in itself? Then setting up additional lan/ vlans further separates the users virtually but not physically. Will the networks 2 and 3 be safer with user separation?
It is Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System. Wireless 2 and 3 say :Allow IoT devices to see each other and access my local network On wireless 1 says
Name (SSID) ORBI30 Broadcast Name On Wireless AP On
if i use advanced setting lan setup to activate lan 2 and assign a VLAN group; then wireless setup and assign wireless network to a VLAN? How does the advanced vlan/bridge Ethernet port setting correspond with the lan and wireless vlan settings? Then will Users or devices not be able to see one another?
My lan Ethernet ports under vlan/bridge settings are setup as access points for the base and one satellite, and vlan is set as default.
when I assigned vlan in lan and wireless setup , separation did not show on advanced home summary screen.- schumakuGuru - Experienced User
Each VLAN does make a dedicated network. Of course, physically on the same network. Industry standard in the IT industry. Multi-tenant data centers operate VVLAN where each customer has his own full ability to use all VLANs possible. And everything can be on the same physical network. Nothing wrong with this.
The WiFi client separation is a different thing - it does just prohibit by some clever L2 MAC filtering that wireless clients can communicate direct. That's why you don't see this enabled. For most use case, this is not a feature you want on your wireless...
