Koesbeenian's avatar
Oct 04, 2020
Armor not visible in app
I have Orbi AX6000 RBK853 (1x router, 2x satellite) purchased in March 2020. At that time, I remember Armor was not yet available for my setup but to be introduced soon. Now I've udated firmware V3.2.16.6 but can't locate the 'security tile' to install armor in the app. Also the app keeps referring to Nighthawk and Insight which to my knowledge are not suitable for my system. I'm a bit lost about wat can, can't, what's promissed, possible, payed or free.
Can anyone shine a light on this?
Thanks Arie
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Koesbeenian,
    May you reinstall the Orbi app and let us know the security tile does not appear in the app.
    Thanks,
    Christian
    • Koesbeenian's avatar
      Koesbeenian
      Tutor
      Unfortunately I can't log into the app now annymore
      Login (adding correct email and password)
      Verify identity
      Code via mail
      adding code in app
      "Want to add iPhone as trusted device?"
      Yes
      Unable to add your device
      What could cause this?
        Koesbeenian
        Tutor
        Okay, I'm in by selecting "do not trust device". Strange but it worked.
        Christian_R Armor tile still not visible.
        I'm on firmware version V3.2.16.6_1.4.4, so latest.
