Purigading
Aug 09, 2020Aspirant
Armour Seccurity and Orbi
I have model (RBK50) AC3000 , which I could not locate in the pull down windows when typing this so just selected anything to get things moving. But it is a (RBK50) AC3000 with 3 satellites.
I have 2 questions:
Since installing the Armour Security with Bitdefender in my Android phone the Orbi app shows only the Orbi main router in green - but the 3 satellites are all in red. Is this supposed to be so?
Next, I tried to disconnect the "security" on the mobile phone app (android) in settings/security but all I get is "disabling NETGEAR armour", and then it times out without completing the disconnection. I tried many times, same all the time.
Would appreciate any help that can be provided to me and I thank all in advance for any such help given me.
Cheers, Gerry (Perth, Australia)
- MstrbigMaster
Purigading wrote:I have model (RBK50) AC3000 , which I could not locate in the pull down windows when typing this so just selected anything to get things moving. But it is a (RBK50) AC3000 with 3 satellites.
I have 2 questions:
Depending on how you have your bitdefender set. Go to a PC and go to http://orbilogin.com/ and check if you see the satellites. Disable Armor and check if you see them in the app.
Purigading wrote:Since installing the Armour Security with Bitdefender in my Android phone the Orbi app shows only the Orbi main router in green - but the 3 satellites are all in red. Is this supposed to be so? No. This should not happen.
"Armor" is what Netgear means by "Security" in the Orbi "app". Similar to the way "Parental Controls" means "Disney Circle".
Questions about the Orbi "app" often get a more informed response if you post in the Netgear community forum devoted to the app:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Not having ever activated Armor myself, I have a suspicion that "something is messed up" between your Orbi and the "app" and the only way to correct things is to do a "Factory Reset" and set it up again. Next time, you might be better off to say, "No Thanks" to Armor.
Maybe someone in the App forum will have a better suggestion.
- PurigadingAspirantThanks ...factory reset of the Orbi or my main router? Is the software for Amour inbedded in the Netgear app....and will always be there until it is removed or expired? Cheers Gerry
- MstrbigMaster
Purigading wrote:
Thanks ...factory reset of the Orbi or my main router? Is the software for Amour inbedded in the Netgear app....and will always be there until it is removed or expired? Cheers GerryHopefully factory resetting the Orbi router fixes it.
