TuborGold
Jul 06, 2026Aspirant
Can't Activate Armor
I know this is common and I have tried all the listed solutions here in the community that I can find. When I try to activate my armor subscription via a code on the armor management website I get t...
Jul 06, 2026Guru - Experienced User
What model Orbi are you using Armor with?
What mobile platform are you using? Android or Apple?
Something you'll need to contact NG support about and have them help with your subscription. All that can't be done from the forums.
