Elisern
Jan 17, 2026Aspirant
Having all kinds of problems with my 8 month old rbr760 and my 3 month old cm 3000 modem.
Why not just share with all of us?? :-/
Jan 17, 2026Guru - Experienced User
What problems are you having on the CM modem and Orbi system? Need more details here.
You can set up any Orbi system with out having Armor. Just factory reset the RBR and setup from scratch with a wired PC and web browser:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
If Armor is disabled, then it's disabled. Or enabled. It's apart of FW and can't be removed.
For the CM modem:
Which ISP are you connected with?
Please post a copy and paste of the modems connection status and event log page.
On the Orbi system:
Is IPv6 enabled or disabled?
Using ISP detected DNS or custom DNS?
