ChemicalGilroy
Aug 11, 2018Star
How to Launch Vulnerability Scan?
As the title says, how can I launch a vulnerability scan with netgear armor on my NightHawk R7000P? There is nowhere in the menu to launch one and I have had it since launch and no scan has been perf...
JohnBaltimore
Sep 24, 2018Tutor
My router has been installed for almost two weeks and it has not done a scan. What's up? How do I force a scan?
I'm thinking I won't be continuing this service after the 90 day trial. Seems pretty crappy. I can't manually start a scan?!
What if my network was infected and I think I cleaned it, but I want to scan again to make sure. I have to wait a week? That's crazy!
Xenia
Oct 08, 2018Initiate
Good points.. I guess you may not need a manual scan b/c if your device still has an issue Netgear will provided another alert?
But it be nice to do a Manual scan? I also have some devices it scanned another’s it never scanned and it been weeks why? What date and time does it scan the devices ?
- XeniaOct 08, 2018InitiateApologies I re read the response above and it appears it scan everytime app is started correct? Anyway I still have one issue If so how come some of my devices it never scanned and it been weeks?
- jimyjamesJan 05, 2019Aspirant
While I'm still trying to figure out netgear armor myself I've noticed that when I installed bitdefender on my laptop from the armor app and did a manual virus and vulnerability scan from the device itself the results showed up on the netgear armor app.
- JohnBaltimoreJan 05, 2019Tutor
I ended up cancelling Netgear Armor. Even with the significant price discount they offered, it just isn't worth it. I think it does very little.
I'm still using my Netgear router as an access point, but I've transitioned to OPNsense for the firewall. It's amazing! It does a phenominal job of protecting the network. Lots of services including netflow analysis, OpenDNS, OpenVPN, dnsmasq, monit, and the list goes on and on. I highly recommend it. It's free, based on FreeBSD, and runs on minimal hardware. I built a small i3 system in a cute little ITX case and it's working perfectly, but I could have just as easily loaded it on an old PC with two NICs.
