ChemicalGilroy
Aug 11, 2018Star
How to Launch Vulnerability Scan?
As the title says, how can I launch a vulnerability scan with netgear armor on my NightHawk R7000P? There is nowhere in the menu to launch one and I have had it since launch and no scan has been perf...
BinkyTheClown
May 23, 2019Guide
I installed Bitdefender on my Mac Pro. There is no application or icon or anything other than an "uninstall" folder in Applications. So not only can I not start a manual scan, I can't even look at anything such as logs. How is one to know if the tool is even doing anything or whether it ever did anything? Trust? I've never used Bitdefender before, but it has very good reviews. I'm assuming that the Netgear Armor variant is some crippled version of the Bitdefender. Also, having to use the lame app to "manage" this is really annoying as well. I'm going to let this sit for a week or so but most likely I'll be removing it. This tool is supposed to make me feel more comfortable not less.
DexterJB
May 23, 2019NETGEAR Moderator
Hi BinkyTheClown, please make sure you follow the steps provided on the link below.
https://kb.netgear.com/000059549/How-do-I-install-Bitdefender-local-protection-on-my-macOS-device
Please let us know if you run into issues.
Dexter
