ChemicalGilroy
Aug 11, 2018Star
How to Launch Vulnerability Scan?
As the title says, how can I launch a vulnerability scan with netgear armor on my NightHawk R7000P? There is nowhere in the menu to launch one and I have had it since launch and no scan has been perf...
NateW
Jul 12, 2019Aspirant
For what it's worth, Bitdefender Total Security has an option on the left hand side called "Protection". Click that and then look for Vulnerability section. If you see that, click on "Vulnerability Scan". That will launch the scan and you'll get results from that afterwards. As for updating the "Last Vulnerability Scan" field in the Netgear Armor dashboard, it takes a while. I suspect the weekly scan mentioned in other comments is required for that. When I click on Update after clicking on the ellipsis icon for my listed device, it just says "... the command is pending."
As for results, the BitDefender UI should give you the information you need, whether or not there are actual vulnerabilities.
