wuzcsg's avatar
wuzcsg
Tutor
Oct 10, 2020
How to turn off Netgear Armor?
Hi,
My model is Nighthawk RAX20 Dual-band AX4 WiFi 6 Router - AX1800 and I just changed from Google Wifi.
After changed the RAX20 I found something strange.
  1. I can't turn off the Netgear Armor.
    I know it's in the admin app but no matter how I tried, it always showed: "Disabling NETGEASR Armor.", then  "Process is taking too long (more than 60 secs) Try again!!"... Really no words, such bad user experince.
  2. I used speedtest to test, before Google Wifi was always around 600-700Mbps (download), but now I only got 100-130Mbps..., are you kidding me??
Does anyone can advise?
Thanks
James
