mapping
Sep 27, 2023Aspirant
Internet Radio stations blocked on AX2400 / RAX30
My RAX30 is blocking my Naim ND5XS from accessing some internet radio stations. These stations are available on other devices – only the Naim is blocked (they all worked on the Naim before changing to the RAX30). The stations are blocked as threats but don’t shown under the list of threats in the app so they can’t be unblocked. They are shown as ‘anomaly’ – there are 13 threats shown but only 5 are actually listed as real threats, the rest are radio stations and I cant unblock them – can you help?
What happens if you disable Armor temporarily in the NH app?
Select the 3 horizontal bars top left corner, then select Settings/Security then move the slider button to disable Armor.
- mappingAspirant
Hi - with Armor disable the radio blocking station continues.
With Armor and any other security app (Smart Parental Controls or Access Controls) disabled, power off for 1 minute then back ON with the ISP modem and router.
Turn off and unplug modem.
Turn on computers and rest of network.
