needhelp___'s avatar
Mar 28, 2025
need technical help
A blue screen occurs due to a conflict with the A8000 product and the game's EasyAntiCheat program.
I am seeking help here since the free technical support period has expired.
  • Because before I plugged in the Netgear product, the blue screen wouldn't pop up, and after I plugged it in, the blue screen popped up. And, what's the point of the game? It's important to use an anti-cheat program called EasyAntiCheat that turns on when the game is running.
    • plemans's avatar
      Isn't "easy anti cheat" pretty close to a virus?
      Have you tried uninstalling that and running the adapter?
      Or installing the stand alone driver?
      • needhelp___'s avatar
        needhelp___
        Tutor
        Yes, of course. East Anti Cheat often conflicts with other programs, but not this time.
        I tried uninstalling and reinstalling the adapter, and also checked the integrity of the EasyAntiCheat and reinstalled it.
        I didn't and I don't have any information of this work, so I want you to teach me what is this.
        I would appreciate it if you could tell me if it is a simple home remedy that can be done through the WIndows Control Panel. It doesn't necessarily have to be specialized knowledge.
        Thank you for your interest and help.
