datadave27
Aug 01, 2018Aspirant
Netgear Armor R7000 in AP Mode
Does anyone know if Netgear Armor works on the R7000 in AP mode? I was going to give the product a try for testing purposes as I already have Bitdefender and Bitdefender Box 1 I am getting rid of the...
- Sep 11, 2018
Netgear Armor does not work when the router is in AP mode. An error message will appear when the router is in AP mode.
~Christian
ktlsfc
Sep 07, 2018Tutor
Is there an answer to this? Can Armor work when the R700P or other Netgear routers are setup as AP?
datadave27
Sep 07, 2018Aspirant
Not that I am aware of I’ve done some research and not found any results. I actually almost forgot about this, I’ll try and contact support and see if they have an answer.
