datadave27
Aug 01, 2018Aspirant
Netgear Armor R7000 in AP Mode
Does anyone know if Netgear Armor works on the R7000 in AP mode? I was going to give the product a try for testing purposes as I already have Bitdefender and Bitdefender Box 1 I am getting rid of the...
- Sep 11, 2018
Netgear Armor does not work when the router is in AP mode. An error message will appear when the router is in AP mode.
~Christian
ktlsfc
Sep 07, 2018Tutor
Is there an answer to this? Can Armor work when the R700P or other Netgear routers are setup as AP?
Christian_R
Sep 11, 2018NETGEAR Employee Retired
~Christian
- datadave27Sep 11, 2018AspirantThanks for the update I kind of expected that much so I’ll just look to upgrade my perimeter security I only really use the Nighthawk for my iot devices for the most part, thank again!
Cheers- Christian_RSep 11, 2018NETGEAR Employee Retired
Sure thing! If you have any other question, we are here to answer!
Enjoy the rest of your day!
~Christian
