gazorn
May 18, 2023Aspirant
Netgear Armour unable to unblock access
IOS 16.4 and 16.5
App Version 2.26.0.61
RBR750 Firmware V4.6.14.3
Cannot unblock a web address, see screenshot
Can we get a fix or is it time to drop Netgear Armour?
It is not the easiest solution to find. You need to log into https://armor.netgear.com
and then click on the bell in the top left corner to see blocked addresses. From there you can allow access.
Did you select "Learn More" link in the app message below?
- gazornAspirant
Yes. Had to finally figure how to use the website on my desktop to allow the address.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
