Dustin_V
Apr 07, 2020NETGEAR Employee Retired
New Feature: Unblock URLs with NETGEAR Armor
NETGEAR Armor’s latest feature puts you in control by allowing you to unblock URLs. While NETGEAR Armor automatically blocks suspicious and potentially dangerous websites, if you believe that a website that you want to visit is safe, you can set that URL as a whitelisted, or unblocked, URL.
To Unblock Websites in NETGEAR Armor:
- Launch the Nighthawk or Orbi app from a mobile device that is connected to your router’s network
- Tap Security - The NETGEAR Armor dashboard displays
- Tap Threats Blocked - A list of suspicious URLs NETGEAR blocked displays
- Tap on the URL that you want to whitelist
- Tap Add to Unblocked - A warning displays
- Tap OK
Note: Use caution when you decide to unblock a URL. Malicious websites often look legitimate and might trick you into providing personal information, downloading malware, or even sending money. For more information, see Why does NETGEAR Armor block certain websites?
As one of the most requested features from NETGEAR Armor users, we’re glad to be able to add this while continue to improve the NETGEAR Armor experience. Let us know what you think about this new feature below!
- KscelfoInitiateThis feature needs to allow the typing in of URLs. It is tremendously annoying to have to unblock every variation of a URL from shorteners like amzn.to
- Christian_RNETGEAR Employee Retired
Hi unwdre,
Thanks for confirming. May you try rebooting the router and reinstalling the app. Let me know if there are any improvements.
Thanks,
Christian
- unwdreGuideReinstall? Meaning disable and re-enable?
Hi unwdre,
Thanks for getting back. I'd like for support to look into this further. If you wish to be contacted, please send me a private message with your contact info.
Thanks,
Christian
- unwdreGuide
Spoke with Level 2. They were no help. Suggested I submit the website to Bitdefender to review which doesn't address the issue and not a functional solution. Will be disabling it until it actually functions correctly.
- unwdreGuide
Doesn't work. I had a site that I clicked unblock for and it's still being blocked.
Hello unwdre,
May you confirm that the URL is in the "Unblock" tab.
Thanks,
Christian
- unwdreGuide
Sure. It actually is happening on all URLs I've tried to unblock.
http://cdn2.editmysite.com/js/site/main-mobile.js
- saulllyAspirantIs there anyway to manually add to unblock?!It’s 4:21am and I was woken up to my phone and tablet buzzing nonstop! Are you telling me I have to click each URL and unblock the last 65 individually?! The only other option would be to turn Security off and that would defeat the purpose of even buying Security...this is ridiculous!!
- unwdreGuide
Don't even bother. Clicking unblock didn't do anything for me. Those sites were still blocked. I ended up turning it off. Half baked product with no options/config etc.
- ZebMGInitiate
The Unblock URL option (as reported by others here) does not appear to do anything. When I click Unblock URL, I get a confirmation that the URL has been blocked. However, the URL does not show up in the listing of Unblocked URLs (nothing shows up there) and the URL continues to be blocked.
Router Firmware: V2.5.1.8
Android App Version: V2.4.25.961
- philips21Initiate
After unblocking a site it shows up in my unblocked list, but appears there it NO option to be able to re-block a site you have unblocked? Am I missing something here? Please tell me this isn't true!
- philips21Initiate
Ok I figured out how to re-block and unblocked site, but it doesn't work like it should.
To unblock a site you can either click on the site or swipe left.
BUT....
To re-block a site you can't click on it, you can only swipe left.
This is not intuitive and should work the same way.
I maintain a website for my church and on 4-21 ARMOR blocked three googleapis.com sites and I can no longer update my church website and when unblocking the site, including turning off ARMOR, and rebooting my router, I still cannot access the site.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
