sreeni_n92
Aug 27, 2019Tutor
When will the Armor will be implemented for Nighthawk R8000P
When will the Armor will be implemented & available for Nighthawk R8000P ? (I see its available for R8000 models now)
- Mar 03, 2020
Hi,
Yes, I was just typing a post to let people know that we have started releasing the firmware in batches. If you are eager to get started, please manually update the firmware by following instructions in https://kb.netgear.com/000061737/R8000P-Firmware-Version-1-4-1-50 and then you can activate Armor 30-day free trial by following https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app.
SimonB1979 Unfortunately, the subscription transfer is NOT automatic - it's tied to original device. DarrenM please DM SimonB1979 to get his information so we can transfer the sub over.
SimonB1979
Jan 19, 2020Star
Any News Guys? 😇
AbhayB
Jan 19, 2020NETGEAR Employee Retired
Hi all,
Sorry for the delay to reply post new year with holidays and our rocking CES show. With additional testing schedule, at this point, it looks like it may be released next month. I will try my best to ensure that it doesn't get pushed out.
- rarriveraJan 27, 2020Aspirant
Ok thanks for responding. I look forward to another solid Netgear app.
- sreeni_n92Feb 01, 2020Tutor
- SimonB1979Mar 03, 2020Star
New FW installed and Armor is working canny! 👍🏻
I appear to be on a 30 day Trial even though I've got 175 days left on my sub but hopefully that'll sort itself out! 😀 - AbhayBMar 03, 2020NETGEAR Employee Retired
Hi,
yep I'll need my Armor Sub transfered from my R8000 to the R8000p! 👍🏻
The Routers (including serial numbers) are registered to my Netgear Email so there shouldn't be any problem! 🍺
Simon
- rinthosMar 08, 2020Luminary
Hello, I just wanted to say Thank You for being transparent about adding Armor to the R8000P! I've activated the trial and plan to purchase the subscription before it ends. Thanks for continuing to invest in this product, and for the continued support, much appreciated!
AbhayB wrote:
Hi,
