sreeni_n92
Aug 27, 2019Tutor
When will the Armor will be implemented for Nighthawk R8000P
 When will the Armor will be implemented & available for Nighthawk R8000P ?  (I see its available for R8000 models now)
- Mar 03, 2020
Hi,
Yes, I was just typing a post to let people know that we have started releasing the firmware in batches. If you are eager to get started, please manually update the firmware by following instructions in https://kb.netgear.com/000061737/R8000P-Firmware-Version-1-4-1-50 and then you can activate Armor 30-day free trial by following https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app.
SimonB1979 Unfortunately, the subscription transfer is NOT automatic - it's tied to original device. DarrenM please DM SimonB1979 to get his information so we can transfer the sub over.
shadowsports
Aug 27, 2019Hero
Its availble on the R8000P now (1.4.1.42) - I just installed this FW a few weeks ago and ignored its prompt. You can purchase BitDefender outright, no need to go through Netgear for it.
- myerswAug 27, 2019Master
shadowsports wrote:You can purchase BitDefender outright, no need to go through Netgear for it.
Have run BitDefender for years on PC's and MAC. Never an issue, just works and protects. Keeps coming with more extensions for browsers to cover more possibilities of bad folks trying to do something. They also make a box that sits between the modem and router if you like the sounds of Armor. I am not sure how much additional load Armor puts on the CPU in the router, that would be a concern of mine.
 - cfansoonNov 11, 2019Guide
I don't think R8000P can activate Armor, otherwise why netgear's website does not list it under their Armor router list? while R7000P is listed along-side R7000.
If R8000P can activate Armor, I will go to my local computer store to purchase it immediately.
I went to my local computer store yesterday, they have R8000P and R8500, but don't have R8000.
They said R8000 is an old model, R8000P is newer, they are not going to re-stock R8000.
- AbhayBNov 11, 2019NETGEAR Employee Retired
Hi all,
I am the PLM at NETGEAR for R8000P. We are, at this point, actively working on Armor support on R8000P - it's in external beta and QA phase. We hope to roll it out before end of the year. We will be testing it to make sure there's no loss of performance.
Thank you for your interest.
- myerswNov 11, 2019Master
AbhayB wrote:Hi all,
How many features are going bye bye with the addition of Armor on the r8000p like DLNA and TimeMachine? Was a surprise to folks that had a router and added latest firmware and then poof things they were using were gone. Netgear has done very poorly in announcing these changes. The answer of well don't update then is not a good answer. That then means if a security update comes out the user cannot update for the security fix without losing a feature they are counting on. Really bad form. With the way firmware support has been in the last year it appears no one is paying any attention. Same bugs for a year with multiple firmware updates. Made me trash a r8000 and r8000p and go else where. Watching the forums things do not seem to be improving.
Other thing is if folks looked around they would find two vendors offering a similar security package for no charge and have the features that Netgear dropped. Probably better firmware and support as well from what I read on forums.
