sreeni_n92
Aug 27, 2019Tutor
When will the Armor will be implemented for Nighthawk R8000P
When will the Armor will be implemented & available for Nighthawk R8000P ? (I see its available for R8000 models now)
- Mar 03, 2020
Hi,
Yes, I was just typing a post to let people know that we have started releasing the firmware in batches. If you are eager to get started, please manually update the firmware by following instructions in https://kb.netgear.com/000061737/R8000P-Firmware-Version-1-4-1-50 and then you can activate Armor 30-day free trial by following https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app.
SimonB1979 Unfortunately, the subscription transfer is NOT automatic - it's tied to original device. DarrenM please DM SimonB1979 to get his information so we can transfer the sub over.
cfansoon
Nov 11, 2019Guide
I don't think R8000P can activate Armor, otherwise why netgear's website does not list it under their Armor router list? while R7000P is listed along-side R7000.
If R8000P can activate Armor, I will go to my local computer store to purchase it immediately.
I went to my local computer store yesterday, they have R8000P and R8500, but don't have R8000.
They said R8000 is an old model, R8000P is newer, they are not going to re-stock R8000.
AbhayB
Nov 11, 2019NETGEAR Employee Retired
Hi all,
I am the PLM at NETGEAR for R8000P. We are, at this point, actively working on Armor support on R8000P - it's in external beta and QA phase. We hope to roll it out before end of the year. We will be testing it to make sure there's no loss of performance.
Thank you for your interest.
- myerswNov 11, 2019Master
AbhayB wrote:Hi all,
How many features are going bye bye with the addition of Armor on the r8000p like DLNA and TimeMachine? Was a surprise to folks that had a router and added latest firmware and then poof things they were using were gone. Netgear has done very poorly in announcing these changes. The answer of well don't update then is not a good answer. That then means if a security update comes out the user cannot update for the security fix without losing a feature they are counting on. Really bad form. With the way firmware support has been in the last year it appears no one is paying any attention. Same bugs for a year with multiple firmware updates. Made me trash a r8000 and r8000p and go else where. Watching the forums things do not seem to be improving.
Other thing is if folks looked around they would find two vendors offering a similar security package for no charge and have the features that Netgear dropped. Probably better firmware and support as well from what I read on forums.
- cfansoonNov 17, 2019Guide
Wow, that is great.
I just bought a R8000P yesterday for my another network.
Now waiting for the armor.
- CFS_3764Nov 20, 2019Tutor
Could I install the beta version armor on my R8000P?
I bought this router few days ago.
I understand the beta version is not fully optimized for R8000P yet, so I understand it is on my own risk to use beta version, and I will not post complain about this beta vesion in this forum.
- AbhayBNov 21, 2019NETGEAR Employee Retired
I have passed on your request internally. It may take some time to get back but you can DM me if you don't hear back in a week or so.
- rarriveraJan 02, 2020Aspirant
Hi Abhay,
I Would love to be part of the Armor Beta to. I'm a network engineer and PC support tech. This would be something I would use extensively. Please let me know if this is possible.
Thanks,
Raymond
- SimonB1979Nov 30, 2019Star
AbhayB 😇
Could I also have a copy of the beta R8000P FW please? 👏🏻
Simon 🤓- d-luxDec 26, 2019Aspirant
Has this been released yet?
I can not seem to figure out how to get the Armor feature running on my R8000P.
Any inuput helps!
- sreeni_n92Dec 27, 2019Tutor
Hi Abhay, Any update on this? Could you pls update when the new firmware will be released (with Armor feature) ?
- SimonB1979Dec 28, 2019Star
AbhayB 🤓
yep! an update would be nice! 👍🏻
Armor works quite well on my R8000 but would obviously prefer it on R8000P instead! 👏🏻
