eyrieowl
May 06, 2019Tutor
Circle Home Plus
Hey, So, I recently moved from a Nighthawk R7000 I'd been using for several years to an Orbi system. I'm in general happy with the Orbi...but I've run into difficulty in setting the parental cont...
eyrieowl
May 06, 2019Tutor
Also, just to add, I'd really appreciate a forthright answer b/c I have subscriptions I'm paying for for both Circle and Circle Go, and I'd like to have clarity on whether I should cancel those as they'll be useless, or not....
- MastersuntzuMay 21, 2019InitiateI’m in the same boat. My R7000 Nighthawk died during the latest firmware update. Rather than fight the inevitable, I accepted its death and proceeded to BestBuy to purchase a new router with WiFi. I chose the Orbi because I wanted to continue using Circle and CircleGo. I can’t begin to explain how frustrated I am that I now have to purchase the Circle Plus too! Will Orbi be updating its firmware/OS to support Circle Plus?
- schumakuMay 25, 2019Guru - Experienced User
Appears there are multiple misunderstandings....
- Premium for Circle on Netgear requires only the Circle subscription, not both Cirlce and Circle Go. If you have both subscriptions charged on your account, please look here -> https://support.meetcircle.com/hc/en-us/articles/360003335191-Two-Subscriptions-Appear-for-My-Circle-Account
- The "standalone" Circle by Disney solution (with the Circle box - which is not required with the router based Circle on Netgear) is replaced by the Circle Home Plus.
- The feature set of Premium for Circle on Netgear -> https://support.meetcircle.com/hc/en-us/articles/115001380692-What-is-Premium-on-Circle-with-NETGEAR- continues to be available.
- MastersuntzuMay 25, 2019InitiateThere is no misunderstanding. I am aware of your three points. The issue is that if I want to continue managing my kids iPhones outside of my home I will now have to purchase separately the new Circle box. Prior to Circle discontinuing Circle Go I could manage devices within and outside of my WiFi network. With the new arrangement there is ZERO value in having Circle via Netgear. Once I purchase the new Circle Device I will have all the features of Circle without Netgear adding any value. In short...why select a Netgear router with Circle included when you will have to buy a separate Circle device anyway. As angry and frustrated as it makes me I have conceded that I will need the new Circle device to continue managing my devices the way I was able to prior to this awful change in the Netgear/Circle partnership. I will now have to disable the Circle feature on my Netgear Orbi so that the two different Circles/Profiles don’t conflict/compete with each other.
