Goosey_Gander
Aug 30, 2019Aspirant
Circle limits the speed of gig router by more than half.
I have fiber coming to my house so my internet speeds run 950Mbps download at the modem, into the router and to my computer via wifi UNTIL I enable Circle Parental controls. My speeds immediately sink...
seabass0118
Sep 15, 2019Initiate
I can confirm having terrible internet speed being my orbi to the point of my fiber-to-the-house gigabit service reports full 1k speed at the modem, but ip calling app suggesting that my network is bad enough to be inadequate for normal VoIP when alone in the house... Ridiculous!!!
DexterJB
Sep 16, 2019NETGEAR Moderator
Hi seabass0118, are you having a similar issue wherein you experience slower Internet speed when the Circle feature is enabled? If yes, the case is currently being worked on and has been reported to the engineering team. We will provide an update as soon as it is available.
Dexter
- DarundoOct 20, 2019Aspirant
DexterJB wrote:Hi seabass0118, are you having a similar issue wherein you experience slower Internet speed when the Circle feature is enabled? If yes, the case is currently being worked on and has been reported to the engineering team. We will provide an update as soon as it is available.
Dexter
Hi Dexter,
Following up on this - is there somewhere where we can track the status of this issue or can an update be provided?
Thanks
